Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: I need a Tool to pull the Steering Wheel?
    Dec 2006
    Atlanta Georgia
    I have removed my cluster several times without removing the steering wheel. My method may not be easier though. I remove the trim cover under the steering wheel (the large one held on by about 8? screws) then it is 2 13 mm bolts holding the enire steering column up. Remove these and lower the column to down. Now there is plenty of room to remove/install the cluster.
    May 2006
    NH
    Quote Originally Posted by cobb535
    Well if i am too nervous about dealing with the airbag off the wheel and worry about triggering it by dropping it or bumping it i can always try that way.. thanks. haven't taken the time to get around to this yet thoigh..
    1995 540i Manual build 1/95
    5 minutes tops to pull the wheel. The airbag is no big deal, disconnect the battery and you can't set the SRS light.
  1. Replies: 5
    Last Post: 12-18-2006, 10:18 PM
  2. where can I get a wheel cap removal tool?
    By bbig119 in forum 5 Series BMW
    Last Post: 05-21-2006, 11:52 PM
  3. Clickin noise from wheel/lumping in steering wheel
    By m5james in forum 7 Series BMW
    Last Post: 11-19-2005, 11:26 PM
  4. What should a pick n' pull steering box cost?
    Last Post: 07-08-2005, 10:03 PM
  5. Wheel aligment/steering wheel question.
    By Don (Ireland) in forum 5 Series BMW
    Last Post: 08-25-2004, 06:04 AM
