Results 1 to 4 of 4
Thread: Stomp Test Code 1213
    Nov 2006
    Columbus, OH
    Default Stomp Test Code 1213
    Which O2 sensor is this one, code 1213, left or right side?
    heh... probably an intake leak, very common as the weather gets colder. Reboot the computer and youll probably get another code, all coming from a leak.
    Nov 2006
    Columbus, OH
    Thanks.
    I cleared the codes several days ago and got the same code the next morning. It is getting colder here, around the mid to low 30's. I recently had the water pump replaced, and later the thermostat housing replaced. I will check the setting again and the intake connections and fittings.
    most likely the intake gaskets and plate gaskets, did mine big improvement but forgot to do the front plate...someday i'll pull it back off and do it all right.
  1. m60 fault code 1213 ???
    By motuman in forum 5 Series BMW
    Last Post: 01-11-2010, 12:09 AM
  2. OBC Code on stomp test
    By Jazzman in forum 7 Series BMW
    Last Post: 12-22-2009, 08:04 PM
  3. Blink Code Pedal Faults- Stomp Test
    Last Post: 11-19-2008, 01:57 AM
  4. Code stomp test?
    By pundit in forum 5 Series BMW
    Last Post: 03-22-2005, 12:14 PM
  5. Got a 1221 code after stomp test, need direction
    By pismojeff in forum 5 Series BMW
    Last Post: 12-15-2004, 05:48 PM
