which side?
Happen to anyone else? Should I be concerned or am I just paranoidWhile I was driving (finally driving my car, probably registered and fully functioning, just ONE bulb to change before perfection) down a highway at around 50 one of the warning lights flashes at me, just for a moment. Not even sure which one, it was night so it stuck out. Just freaked me out last time a light came on my car was dead within 30 seconds! I think it might have been the light with an exclamation point, or maybe srs? On that side of the cluster..
which side?
-Mike
Right side of the cluster. My car has the canadian symbols for the warning lights, exclamation point I thought was SRS but my car doesn't have SRS and that doesn't make sense. Its to the left of ABS. Still not sure which light though, for all I know it could've been park brake (it was red). def not check engine thoughOriginally Posted by Sam-Son
check engines on the other side....brake pads maybe?
-Mike
Don't think theres a separate warning light, I've had the brake linings message on for ages... brake pads don't take the sensorsOriginally Posted by Sam-Son
brake fluid lowOriginally Posted by nirvana19
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
Yes, but with that one you also get the "brake fluid low" warning to go along with the warning light.Originally Posted by bmwrp8
Hmm well the brake fluid is at the maximum level which I confirmed, it should be because when I took the car in for inspection the only thing that needed repair was a twisted brake hose so they bled/filled the system. I have BRAKE LININGS on all the time while driving so I must be missing some messages. hmm any other possibilities? it was only on for a couple seconds if not less, it was just odd. What exactly does the (!) light mean?Originally Posted by Torque
check your messages, had that light once (!) red beside park brake and ABS. and like what torque said it should be accompanied by brake fluid low in CC. if you fluid is high check the floater might be stuckOriginally Posted by nirvana19
You should get that brake linings warning fixed (Brake pad sensor?). You don't want to burn that LCD out.Originally Posted by nirvana19
