Results 1 to 10 of 12
Thread: Random Warning Lights!
    Jun 2006
    Bethesda, MD
    Default Random Warning Lights!
    Happen to anyone else? Should I be concerned or am I just paranoidWhile I was driving (finally driving my car, probably registered and fully functioning, just ONE bulb to change before perfection) down a highway at around 50 one of the warning lights flashes at me, just for a moment. Not even sure which one, it was night so it stuck out. Just freaked me out last time a light came on my car was dead within 30 seconds! I think it might have been the light with an exclamation point, or maybe srs? On that side of the cluster..
    Behind the wheel of My Car
    which side?
    -Mike
    Jun 2006
    Bethesda, MD
    Quote Originally Posted by Sam-Son
    which side?
    Right side of the cluster. My car has the canadian symbols for the warning lights, exclamation point I thought was SRS but my car doesn't have SRS and that doesn't make sense. Its to the left of ABS. Still not sure which light though, for all I know it could've been park brake (it was red). def not check engine though
    check engines on the other side....brake pads maybe?
    -Mike
    Jun 2006
    Bethesda, MD
    Don't think theres a separate warning light, I've had the brake linings message on for ages... brake pads don't take the sensors
    Feb 2007
    GreenHills East-Philippines
    Quote Originally Posted by nirvana19
    brake fluid low
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    Kentucky
    Quote Originally Posted by bmwrp8
    brake fluid low
    Yes, but with that one you also get the "brake fluid low" warning to go along with the warning light.
    Jun 2006
    Bethesda, MD
    Quote Originally Posted by Torque
    Hmm well the brake fluid is at the maximum level which I confirmed, it should be because when I took the car in for inspection the only thing that needed repair was a twisted brake hose so they bled/filled the system. I have BRAKE LININGS on all the time while driving so I must be missing some messages. hmm any other possibilities? it was only on for a couple seconds if not less, it was just odd. What exactly does the (!) light mean?
    Feb 2007
    check your messages, had that light once (!) red beside park brake and ABS. and like what torque said it should be accompanied by brake fluid low in CC. if you fluid is high check the floater might be stuck
    Long Beach, CA
    You should get that brake linings warning fixed (Brake pad sensor?). You don't want to burn that LCD out.
  1. Attack Of The Warning Lights!!
    By Spasso in forum 3 Series BMW
    Last Post: 02-07-2007, 10:07 PM
  2. Dashboard warning lights
    By royal in forum 5 Series BMW
    Last Post: 11-17-2006, 10:09 AM
  3. Lights-on warning
    Last Post: 07-15-2004, 03:45 AM
  4. ABS and 'Check Engine' Warning Lights
    By simon-york in forum 5 Series BMW
    Last Post: 04-23-2004, 01:38 PM
