Can anyone post a picture of the factory mounting location of the BMW car jack? I cant seem to get mine to fit correctly and was wondering if I am mounting it wrong or if I am missing hardware. Thanks
Greg Mannino
I don't have a pic at the moment but i had trouble figuring it out at first... Assuming you've removed the 'carpety' (if there is such a word i'd be surprised) side panel you will see a bolt sticking out with a sort of butterfly nut on the end of it. If you close the jack fully and look at the curved end you will see a hole in it...Originally Posted by gmannino
You need to insert the thin end of the jack way back into the boot in such a way that the bolt with the butterfly nut on it can go through the hole in the bottom end of the jack. (The winding arm will be above the main arm of the jack...)
Wow this is hard to explain without a picture... I'll try and get one on tomorrow![]()
might i interject that the wrench that comes with the car to remove the lug nuts is next to useless.
100nm +/- 10 or 74 ft/lb +/- 7, according to BentleyOriginally Posted by attack eagle
Been using 90 ft/lb here with anti-seize on threads only for decades with no problem removing.
See, I torqued mine to 105 ftlbs per some torque table I got off here and the local tire guy fussed at me for putting them on too loose! I don't care about what he says as they feel right to me!Originally Posted by Ross
Back on topic...don't you love fighting your jack into place? It comes out pretty easily, but man, getting the nose of the jack back into the spring-loaded clip is a knuckle-buster sometimes!
Brian
i can't get any leverage with that tiny wheel wrench - i bought a good cross and use that instead.
hmmm.. +1 on this also want to see...Originally Posted by gmannino
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
