'89 525 oil leaks. Had three. One down, two to go.
Used Winfred's tip to "crimp the factory clamp tighter" to stop PS leak at the reservoir (see my thread).
Have two engine oil leaks. One seems to be from the rear main and maybe one from the front seal. Engine has 166k. Is that the "they all do that" mileage point, or could something be pressurizing the crankcase to push the oil out. Oil use one quart between syn changes at 7.5k.
Leak may have started recently.
'85 535 with comparable mileage is dry as a bone.
