wow, i've never had that problem.
I've also noticed that when using the heat at night, the heat from the dash bulbs throw the temp sensor off and I need to turn the dials even hotter.
Brandon J
if your heat sucks and the pump works the valves have probably come apart and are blocking the flow, as for getting dual zone to work the drivers side dial can't be at either extreme position, theres usually a little notch that you can feel as it snaps into the full cold/hot position, this overrides the other knob
Originally Posted by Qube
Thats not normal.I start getting warm air after only about 2 kilometres...i am starting to get really warm air when the temp needle is about half way between stone cold and normal.I credit the aux pump for this.It is easily the fastest warming heater of any car i have had.Originally Posted by infurno
dual zone???mine works but really how much temperature differential can you get from warm air in a box say 6x8x 4 feet!My wife constantly plays with the temp dal too,and opening and closing and redirecting the fascia and side ventsOriginally Posted by winfred
mine worked before until whenever I turn the air on the footwell only warm or hot air comes out, no matter if the dial is in cold position so I uninstalled the coolant hose going to the heater core.
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
well before 15 minutes...i get HOT air within a few minutes.On full the thing would be unbearableOriginally Posted by Qube
Ok, I used 15 minutes at a completely full indicator that the car has warmed. In reality of course, yer all right, hot air usually starts going in about 5 minutes, even if it is -20c out.
if everything is working you can get a pretty good split in air temp coming from the vents while the car sorta hovers in the middle, but these things are sorta flow though ventilated anyway, i never tried full heat and full ac but you can get hot and cool but it can take a little while for it to really get going good
i always wondered if you could put a fake dial on the womens side of the car and they would still keep ****ing with it, nothing like a good placebo![]()
Originally Posted by Paul in NZ
Originally Posted by Ferret
^^ What IS that hose? I have replaced my heater valves, the aux pump (was damaged) and found the stepper motor for the center vents had broken away and was stuff on 'cool'. I moved it to hot, but STILL only get partial heat from the center vents. The left vent (in the door) is especially cool. Is there another stepper motor that could have broken away for that vent too?
Anyway, more info on the above procedure would be great.
