Originally Posted by shogun
I've got it direct from a ZF rebuilder, all 4hp22s are the same, case compatible with each other. Basically it means you can take a 4hp22 from any car and swap it into any car, the only changes you'll need to make are the bellhousing and the valvebody. Use those parts from the car you're swapping into and you're good to go.
