Results 1 to 2 of 2
Thread: 4HP22 Remanufactured Starting bid: $ 700
    Default 4HP22 Remanufactured Starting bid: $ 700
    says it is for a 735 E32, but maybe it also fits to the E34?
    Whoever needs one, check it out
    http://cgi.ebay.com/ebaymotors/BMW-7...mZ170166376101
    Jun 2007
    Cheshire CT
    I've got it direct from a ZF rebuilder, all 4hp22s are the same, case compatible with each other. Basically it means you can take a 4hp22 from any car and swap it into any car, the only changes you'll need to make are the bellhousing and the valvebody. Use those parts from the car you're swapping into and you're good to go.
  1. Remanufactured Clusters... Source?
    Last Post: 06-13-2010, 04:57 PM
  2. Python remanufactured AFM
    By SRR2 in forum 5 Series BMW
    Last Post: 03-21-2006, 08:49 PM
  3. Remanufactured MAF
    By Shaun in forum 5 Series BMW
    Last Post: 09-27-2005, 12:00 PM
