do you have the speciality tool set for the rear bearings?
If not, you're in for a world hurt.
http://www.pelicanparts.com/bmw/cata...TOOLS1_pg1.htm
Got a new member of the family, '95 318is. I need to change the rear wheel bearing, took everyhting off, got the collar nut off the hub and I can't remove the hub. Used a side hammer to remove it, still not even I think an increments did move out forward. What should I do, is there any other part I should look into that I didn't remove other than the collar nut? Thanks in advance guys!
Bro I don't have that, was just a side hammer I was using. Kinda costly huh? But good for the long term.
Originally Posted by takumidrift30
I've seen some DIY links out on the web that show a homemade pipe tool that works.
