walk around to the other side and use that doorOriginally Posted by E34turbo
-Mike
seriously though you are locked out of your car? I know they sell kits that allow you to basically break into your own car in case you lock a key inside or something. Not sure where they sell them though. I'll look around
-Mike
i've been told it has to do w/the central locking system. a guy i talked to said if you disconnect the central lock system (i think he said it was the GM) under the seat and your doors unlock then your GM module is bad.
i've yet to try this b/c my car is on the other side of the state but when i do get over there i'm going to try this out! we ended up having to break out the glass to get into the car. and at that the locks took some serious muscle to get them open.
from reading previous posts on this though it might be the door lock actuators. PLEASE lmk what you find out.
dave
http://www.bmwe34.net/e34main/trouble/Locked.htmOriginally Posted by E34turbo
Did you try the emergency unlock procedure? When I locked myself out I did this. Put the key in (don't turn it) hold up on the handle and turn it counter clock wise all the way.
