Results 1 to 9 of 9
Thread: e34 wheels on e38...smaller hub
    Aug 2006
    Default e34 wheels on e38...smaller hub
    i know the hub on the e34 is smaller then the e39, so swapping e39 wheels to the e34 if fine but not the other way around...
    im told the stud pattern is the same on both, and im only out by a few mm...possible to shave a little of the inner of the alloy wheel? im only 1.5 mm out apparently
    Nov 2006
    Mid-Atlantic, USA
    On a lathe, maybe. What are you trying to accomplish? If it'll help, we can probably tell you not to bother!
    Aug 2006
    Quote Originally Posted by BMWCCA1
    doesnt the title give it away! i want to fit e34 wheels on an e38
    Bay Area, CA
    on e38 or e39?
    if on a e38.. (7 series)... no need to do anything.. same hub
    if e39 (5 series).. you should bring to a machine shop to do correctly
    Aug 2006
    Quote Originally Posted by E34N
    on e38 or e39?
    are the e39 and the e38 not the same size?
    Bay Area, CA
    Quote Originally Posted by billy
    what? hubs? no. the e39 hubs are the only different hubs among BMWs
    all e28, e34, e36, e46, e32, e38 have same hub.. offsets.. well, that's a different question.
    Wellington,New Zealand
    e34 e38 e39 all should use same offfsets....but as already stated e 39 has aprox 74 mm hubs all others 72.5
    Gone but not forgotten
    Nov 2006
    Mid-Atlantic, USA
    Actually, I think the X5 has the same hub size as the E39.
    The reason I asked what you were trying to accomplish is because of the expense and possible problems with trying to enlarge the opening. I figured maybe you had some special wheels that would justify the work involved. Just curious. There are tons of wheels available fairly cheap for the E39 because of the odd hub size so I wondered what was so special about what you were trying to put on yours. Sorry if that offended you somehow.
    Aug 2006
    Quote Originally Posted by Paul in NZ
    ah well thats sorts it then, many thanks for your help
  1. Replies: 15
    Last Post: 02-12-2007, 09:28 PM
  2. WHEELS! NY/Proximity plz read! Snatch up these wheels!
    Last Post: 09-11-2006, 05:46 PM
  3. E60 wheels on E34
    By aabdelhamid in forum 5 Series BMW
    Last Post: 03-13-2006, 01:56 PM
  4. Anyone seen these wheels on an e34?
    By colin292 in forum 5 Series BMW
    Last Post: 07-03-2005, 09:57 AM
