Results 1 to 5 of 5
Thread: No Bentley handy... how to remove driver door panel?
    TC535i Guest
    Default No Bentley handy... how to remove driver door panel?
    Tried taking it off, and I'm getting hung up. Door pin removed, all side/bottom clips off, and the center clip is loose. Screw in the door pull removed.
    Seems like it's hanging up around the mirror adjustment? Wasn't obvious as to how it came off, so I figured I'd pop in here before prying it out with a screwdriver... any tips?
    TO, CA, NA, EA
    There is a little screw that holds in the panel behind the button/switch that adjusts the mirrors. That little switch does pop off if you pry it out with a screwdriver. Good luck!
    TC535i Guest
    ok, so just get behind the insert/panel and pop it off? remove knobs first or anything, or just go to town?
    Feb 2007
    Glendale,CA
    just use the e34 ultimate cd
    theres a pdf bentley on there
    1995 BMW 525i E34 M50B25 2.5L (Non-Vanos) -Automatic Transmission- (w/ Cruise Control & Full OBC) *REBOUGHT!!*
    Jun 2005
    Cheshire, UK
    Look up the panel on realoem.com?
    They usually give pretty good exploded diagrams.
    HTH.
    1997 e39 523SEi touring.
  1. How to remove door panel, with faulty door lock?
    By nsbone_1988_520i in forum 7 Series BMW
    Last Post: 08-16-2007, 04:18 PM
  2. How to remove nose panel
    By harrythan in forum 3 Series BMW
    Last Post: 04-25-2006, 10:14 PM
  3. how to remove sunroof panel e36
    By mikes in forum 3 Series BMW
    Last Post: 09-07-2004, 10:13 AM
