There is a little screw that holds in the panel behind the button/switch that adjusts the mirrors. That little switch does pop off if you pry it out with a screwdriver. Good luck!
Tried taking it off, and I'm getting hung up. Door pin removed, all side/bottom clips off, and the center clip is loose. Screw in the door pull removed.
Seems like it's hanging up around the mirror adjustment? Wasn't obvious as to how it came off, so I figured I'd pop in here before prying it out with a screwdriver... any tips?
ok, so just get behind the insert/panel and pop it off? remove knobs first or anything, or just go to town?
just use the e34 ultimate cd
theres a pdf bentley on there![]()
1995 BMW 525i E34 M50B25 2.5L (Non-Vanos) -Automatic Transmission- (w/ Cruise Control & Full OBC) *REBOUGHT!!*
Look up the panel on realoem.com?
They usually give pretty good exploded diagrams.
HTH.
1997 e39 523SEi touring.
