Thread: I got my 535i started but its running bad
    tempe
    Default I got my 535i started but its running bad
    I think the timing is off. The engine starts and and it won't really idle. It revs up to about 3000rpm then dies. I check all the hoses and I don't see any obvious problems. I assume its the timing. I adjusted the block to tdc and then head to the have the valves closed on the #1 cylinder. help...
    Bay Area, CA
    Check the TPS? throttle position sensor.
    tempe
    What should I look for with the tps? should I test with a volt meter?
    Bay Area, CA
    yes... here's the instructions (sorry.. throttle position switch)
    tempe
    thanks allot I will look into it.
    -The ICV might be bad
    -the voltage could be off
    -TPS switch as mentioned above.
    Theres one more thing it could be, but I forget what it is.
  1. Replies: 8
    Last Post: 02-01-2009, 04:41 PM
  2. Any 535i owners running with a chip?
    Last Post: 10-17-2007, 02:48 AM
  3. 535i trans program error when started
    By Eagle in forum 5 Series BMW
    Last Post: 04-16-2006, 09:14 PM
  4. 535i Sport engine running problem?
    By ADD in forum 5 Series BMW
    Last Post: 07-03-2005, 08:33 PM
  5. Project 535i Turbo Started
    By TCD in forum 5 Series BMW
    Last Post: 06-01-2004, 03:16 PM
