Page 4 of 4 FirstFirst ... 234
Results 31 to 40 of 40
Thread: DIY wheel allignment
  1. #31
    Quote Originally Posted by bsell
    I measured from the highest point on the front-side and rear-side of the front tires as I could get while maintaining a tight, straight tape measure. Of course I used the same grooves in the tires, both front and back. As you will need an assistant to hold the other end of the tape against the tire, make sure your helper understands the idea of using the same groove on both sides of the tire.
    After reading the geometry post above, I started wondering what the definition of toe-in really was...so I went to Wikipedia and read this http://en.wikipedia.org/wiki/Toe_(automotive)
    You know this toe-in setting is not that big a deal to do after tackling the job a couple times. Altering the setting a little bit, 1/8th inch, or so can be felt pretty quickly during normal and spirited driving. The tell-tale feathering of overdone toe angle takes more time to show so use good measuring technique and check your work a couple times, then everything will be all right.
    Brian
  2. #32
    Quote Originally Posted by BigKriss
    how much toe in did you give it, or was it just a guess?
    With this tool you do not even have to know toe-in and toe-out, just as described here
    http://www.revheads.com.au/GUTR%20Notes.html
  3. #33
    It was not a guess. Rather, it was a calculation, taking the prescribed toe-in and working backward to estimate how much offset from a straight line is correct when measured at the tire bulge. In other words, there is less offset at the bulge than out at the tread, the tread being further from the pivot point.
    In essence, there should be a straight line (as seen by sighting down the taught thread, when placed horizontally across the equators of the tires) that intersects both bulges of the rear tire, the aft bulge of the front tire, and the outer surface of the 1/16" allen wrench held snug to the front bulge of the front tire by the thread. Run one long and taught piece of thread around the whole car, held in place by a bit of tape. Make sure the thread crosses each tire at its equator, i.e., right across the center of each hub. Then, insert the allen wrench between the thread and that tire sidewall bulge on the front side of the front tire. Adjust toe-in such that the thread is straight across the bulges of the rear tire, the aft bulge of the front tire, and across the allen wrench.
    Start by parking the car on a smooth, level surface with the steering wheel centered and wheels pointed straight ahead.
    Use fishing line or string if thread is not available, or a heavy duty paper clip if you don't have a ~1/16" allen wrench, since they are about the same thickness. 10 or 12 Postit notes from a Postit note pad would also work--anything of correct thickness that is light and will offset the fore tire bulge from a straight line by ~1/16".
    If I could post pictures here, you'd see at a glance how this works. I just rewind the thread on its spool, and put it back in wife's sewing kit until next time. Been doing this for decades.
    Dash01
    '90 535ia 272K miles
  4. #34
    Kris,
    when you order, better reconfirm with seller that the mat is included. Just found this link, where there are options with and without mat
    http://www.demon-tweeks.co.uk/produc...pcode=GUNG4008
  5. #35
    Default more info
    Toe Simplified
    Toe is the pointing in or pointing out of the front wheels as viewed from the top of the car. If the front wheels point in, toward the engine, at the front edge of the wheels then you have toe in. If the front wheels point out at the front edge then you have toe out.
    In general, racecars are set with a small amount of toe out. The toe out provides directional stability. Toe out pulls on the tie rods taking out the tiny clearances that are built into the tie rod ends. Depending on the type of car typical toe readings are 1/16" to �" out for tracks under � mile in length.
    Toe should be checked often as any contact with other cars or retaining walls is likely to change your toe setting. Changes in ride height can have an effect on toe as well.
    Toe can be set with a pair of toe plates that are rested on the sidewalls of the tires. A tape is placed on the toe plates in front of the tire and an additional tape behind the tire. When using toe plates a smaller tape reading on the back tape indicates toe out.
    For a very precise reading you can scribe a line in each front tire. Use a tire scribe and spin each of the front tires to get your straight line. You can then measure between the two scribed lines with a tape measure or with a toe bar. As with toe plates, a smaller measurement at the backside of the tire indicates toe out.
    Some racers use a toe bar to measure the toe that lies against the sidewall on one side of the racecar. On the other side, this toe bar extends past the sidewall by a few inches. A tape is used to measure from the toe bar back to the sidewall. When this system is used a smaller tape reading at the front of the tire indicates toe out. You will notice that this is opposite the two other methods described above.
    Set Toe Properly
    You will get better more consistent results adjusting your toe in settings if you go the extra mile to eliminate variables. You must first decide which technique that you plan to use to take the measurements. Each technique offers different benefits and drawbacks. The methods discussed here will be the Toe Plate method, Toe Bar Method and Tire Scribe Method. If you understand each toe setting technique you will be assured of repeatable results.
    Before you begin taking measurements you must insure that the car is race ready. Ride heights set, weight percentages correct, driver weight accounted for, bump steer set, camber and caster set, Ackerman set, air pressure set, stagger correct....you get the idea. You should also inspect the steering components and replace any that are worn or bent. Center up the steering before you begin. Center the drag link or rack so that the inner control pivots and inner tie rods are centered to each other. Tie rod lengths should be adjusted to match you lower control points if possible.
    String the right side of the car to line up the right front to the right rear. By lining up the right side and starting with the right front in line with the right rear you will eliminate any Ackerman effect that is in the car. If the wheels are turned away from straight when you take your toe measurement the Ackerman effect can add toe out that will not be present when the wheels are straight ahead. Take the time to string the right side and you will get more precise results. Make sure to settle the car and roll it forward just before taking a reading. By rolling forward the caster in the car will pull the front wheels take any clearance in your suspension components all in one direction. Be sure not to let the car roll back after you have rolled it forward. By rolling the car forward each time you will get more accurate repeatable results. Be sure to roll the car back then forward after each adjustment to relieve any pressure in the tire and suspension components.
    When taking toe measurements that utilize the side wall it is a good idea to spin each front tire and mark the high spots on the side wall with a piece of chalk. Jack up the car and spin the RF wheel. Hold a piece of chalk on a jack stand about 1/8" away from the sidewall. Spin the tire and see if the chalk hits anywhere on the sidewall. If the chalk does not leave a mark then move the chalk gradually closer until you get marks on the high spots. Then find the uniform spots on the side wall and orient the tire so that those points will touch the Toe bar or toe plate when the car is on the ground. Lower the car and repeat the process on the other side.
    Toe Plate Method: Toe plates offer fast and easy measurement of the front end alignment. When using toe plates be sure to have the toe plates resting flat on the ground and centered on the tire. You should always be sure to have the toe plates flat against the side wall. Make sure that the plate is up against the side wall evenly on both sides. Air up the tires so that there is not a bulge at the bottom of the tire in the center due to under inflation. Go the extra mile and mark the high spots of the side wall with chalk. Use a tape measure to check the back of the tire and the front between toe plates. The toe plate method should give you a smaller number at the back of the tire if you want to have toe out. Remember that any bent wheels or imperfections in the side wall will affect your settings.
    Toe Bar Method: When using a toe bar make sure that the toe bar is held in the same place on the side wall each time on both sides of the car. Make sure that the toe bar is straight up and that equal pressure is place both front and back. Chalk the wheels and take your measurements. Measure the difference from the toe bar to the side wall on the back and on the front. To have toe out you will need to see a larger measurement on the back side of the tire. This is opposite of the toe plate and Tire Scribe measurement techniques. Any wheel run out or side wall imperfections will have an effect on your readings.
    Tire Scribe Method: Start by scribing a line in each front tire. By spinning the tire and scribing a line with a tire scribe you will take out any variables to to bent wheels or side wall wobbles. Measure the front and back of the tire. A smaller number at the back side of the tire will produce toe out.
    Regardless of the method used you should use care to adjust the tire rods equally so as to keep the geometry of the front end correct. Be sure to tighten all jamb nuts and other steering components as well as visually inspecting the steering system. All three methods can give you good results if you take your time and eliminate as many variables as possible
    http://www.bakerprecision.com/longacr16a.htm
  6. #36
    How about this one?
    http://cgi.ebay.com/ebaymotors/Strin...mZ140203017977
    What I don't understand is how do you set up the string line...
  7. #37
    Default more info
    Subject: 1 degree = 60 minutes (more)
    Author: cheung1 as Patrick C 88 750 160K Posted on: 2008-07-08
    Here is the long description of how I set up my alignment check with a laser balance and the measurements I worked with just as an example of the range of numbers you will tackle. I used one of the laser level like in URL below, seated it over a block of wood that just fit the wheel diameter. Tied both with elastic cord. Best is to use two sets of laser level and wood base on both front wheel so no risk to lose measurement.
    I rolled the 750 up my driveway so the rear wheels just caught the one-inch step by the road going up the pedestrian walkway. The front wheels are approximately 1/3 way up the driveway. Then I mounted the laser level as described above. Now I rotate the level so the red laser dots were casted on the 1/2 inch step of concrete below my garage door, about 18 feet away from the front bumper.
    By doing this I set up the geometry to measure the distance between two red dots at a distance far away from the wheels. Next I took a wood board 6 inch X 6 feet found in my garage and held it up near the front bumper with something steady, in my case two jack stands. The red dots were blocked and I marked their positions on the wood board. Below are my measurements one day after I had a $80 profession alignment job. Despite being careful to match the lengths of new and old left/right drag links the computed toe-in number was way off 18 degrees. If I didn't follow up with an alignment the wrong toe-in was gonna chew up my tires fast.
    Distance of two red dots
    far away at step below garage door (D1 not recorded)
    Distance of two red dots on wood board (D2 not recorded)
    Delta distance D2 - D1 = DeltaD = 2.6875 inches (recorded)
    Note D2 > D1 for toe-in
    Note the precision after decimal not needed, it's there only because I was translating from fraction of an inch to decimal.
    Distance between garage door and wood board L1 = 215.625 inches
    At this point computation to toe-in spec is by solving the right angle triangle. The long edge is L1, short edge is DeltaD/2 (for each of left and right wheels). The angle is therefore atan(DeltaD/2 /L1), expressed in minutes to compare to the spec of 18 min.
    For such a tapered triangle, atan(theta) is almost equal to (theta) itself expressed in the unit of radian. So I am looking at 1.34/215.6
    = 0.00623 was my amount of toe-in in unit of radians.
    To convert radian to degrees you multiply by 180/pi
    0.00623 * 180 / 3.1416 = 0.357 degrees.
    0.357 X 60 = 21.4 minutes.
    So this is my toe-in value--21.4 degrees. That compares favorably with the 18-minute spec and in fact the 750 steers well.
    http://www.harborfreight.com/cpi/cta...emnumber=90980
    Patrick C 88 750 159K
    the complete thread http://www.bimmerboard.com/forums/posts/548307
  8. #38
    Okay forget all this madness.... so you drive straight onto these deals and park right on top right? Giving you the toe in/out reading right? then adjust from there? sheesh it's so simple I don't understand it... LOL
    Have done it today again, who else is doing it?
    We use this one
    I am with you on this too...
  10. #40
    and here how Gert does it
    Alignment, yes you can do it too
    =cheap laser level=
    Alignment, yes you can do it too (reposted in one message)
  1. Replies: 5
    Last Post: 12-18-2006, 10:18 PM
  2. Clickin noise from wheel/lumping in steering wheel
    By m5james in forum 7 Series BMW
    Last Post: 11-19-2005, 11:26 PM
  3. drivers wheel moves backward in the wheel well
    By PhilipJCaputo in forum 5 Series BMW
    Last Post: 10-17-2005, 11:42 AM
  4. new tie rods.... how long till allignment?
    Last Post: 10-17-2004, 05:20 PM
  5. Wheel aligment/steering wheel question.
    By Don (Ireland) in forum 5 Series BMW
    Last Post: 08-25-2004, 06:04 AM
