Yeah - this is the pump. wtf am I supposed to do - that bump hits my crank wheel. Unless I am forgetting something..
Today had its issues but went well overall. One major hang up I had was that the pin that the timing chain guide sits on was knicked up so I ordered a new one. Well, that was easy, but the hard part was getting the old pin out! My friend welded a bead around the end of the pin and we used a pair of vice grips welded to a slide hammer to get it out. Worked! After that it was smooth sailing, mostly.
The only stuff left to do is the timing chain tensioner, bolt the head down on the studs, and then put the cams in and valvecover on for good.
Weird issue though - look at the water pump - there is a circular portion sticking out that hits the crank wheel. WTF Is ithat? This pump is from AutohausAZ and is supposed to be right. I dunno wtf that is all about. Considered grinding it down but it looks like it might do something - not sure.
The outer housing in that photo is identical to a TDS, M51 I think, not a petrol as the TDS has a smaller front pulley.Sorry about crank seal but had brain fade, still worth trying the coke trick! Think the TDS uses the E28 525E block but not sure of that, pump is definately identical to my old one.
See, you're the reason some folks have the urge to pump 300bhp out of a stock 525i!![]()
looks awesome!
-Mike
There is nothing wrong with the idea of 300Hp out of 525i....
It's all about how to make it real![]()
[I][B]1995 525i 66000miles![]()
Looks great Jon..........*yawns*...as usual. I don't think you can ever make something that looks like ****, home run yet again Great Job.
I dont know why your pump has the buldge like that, I just repaced mine this afternoon and I did not have it. I orderd a Hepu from BMA
I guess I don't have to tell you to look into it further. The project looks great , good luck with it.
