Results 1 to 4 of 4
Thread: Replacing flex disk & center bearing - Help!
    Default Replacing flex disk & center bearing - Help!
    I've got my car up on jack stands w/ the exhaust off and the drive shaft out... I got the 2 sections of the driveshaft separated but can't get the center bearing off... It looks like a couple light taps w/ a hammer should release the bearing from the driveshaft but, no go...
    Any suggestions??
    Thanks in advance!
    94 540iA w/ EAT
    97 740iL (SOLD!)
    99 Discovery II
    Apr 2004
    Wellington, NZ
    You could use a puller or..... do like I did and whack the crap out of it with a screw driver and hammer, will slowly work its way off. Just be careful not to damage the driveshaft it self and work your way around the bearing so it comes off straight.
    Obviously this will ruin the centre bearing but, hay, your replacing it anyway!!!
    baton rouge, loserana
    that about covers it, a air hammer works well if you have access
    Quote Originally Posted by SamB
    Default Thanks...
    Will go try it!
    94 540iA w/ EAT
    97 740iL (SOLD!)
    99 Discovery II
  1. Guibo or flex disk where to buy?
    Last Post: 08-02-2010, 05:35 PM
  2. Flex disc and center bearing R & R........
    By JD525IA in forum 5 Series BMW
    Last Post: 12-06-2006, 11:27 AM
  3. Replies: 16
    Last Post: 12-17-2005, 07:07 PM
  4. I'm about to check my center bearing and flex disc
    Last Post: 05-05-2005, 07:07 AM
  5. flex disk
    By sabre in forum 5 Series BMW
    Last Post: 03-06-2004, 01:58 AM
