Results 1 to 2 of 2
Thread: Broken Radiator Drain Plug - 95 530
    Boston & Attleboro MA
    Default Broken Radiator Drain Plug - 95 530
    Hey guys, havent been around in a while had a busy 2007 and all my new employers block message boards.
    So I was investigating a coolant leak and found it at the radiator drain plug. After just touching the plug, it popped off. Its broken off right at the first thread.
    So I am gonna get a new plug and hope I can manage to get the piece stuck in drain out.
    Anyone ever had to do this? Advice on doing that? If all else fails just plug the hole permanently, which I know is a bad idea?
    Thanks
    Current
    2008 M5 6 Spd
    2000 Z3 2.8 5 Spd MSport
    2012 X5 35d Sport
    1995 540i 6 Spd
    1992 535i 5 Spd
    Former
    1995 530iA
    1986 635CSI 5 Spd
    2011 X3 2.8 MSport
    Bay Area, CA
    I would take out the radiator and remove it of all liquids. See if you can get that piece out of there and fish it out whatever. If you need to plug it maybe you can drill and tap a new or have a repair shop weld on a new one.
    Greg Mannino
  1. M60 oil drain plug -need fix
    By wool in forum 5 Series BMW
    Last Post: 07-14-2010, 07:10 AM
  2. Magnetic Oil Drain plug - who is using them?
    Last Post: 10-09-2007, 08:21 AM
  3. Magnetic oil drain plug?
    Last Post: 07-11-2005, 05:49 AM
  4. where is the radiator drain plug on 530I?
    Last Post: 07-12-2004, 02:51 PM
  5. help, I can't find the radiator drain plug
    Last Post: 05-23-2004, 02:43 PM
