Results 11 to 20 of 24
Thread: What ECU Can I Use For 4.0 Swap?
    Aug 2005
    It does not matter as the tranny has it's own ECU for an AT, not sure about the 6-SP. I used the ETM electrical wiring diagrams to compare my 4.0 ECU to be used with my 3.0L AT and it had it's own ECU for the AT so it works fine.
    Jul 2007
    Long Island, NY
    Thank you! Much appreciate all the info!
    -AJ
    -Two E30s, an E34 and an E46-
    Reading, UK
    You can use the 540i ECU - but you have to swap the ignition barell over from the 540i, as well as the sensor ring, logic unit in the steering column and all the other bits and pieces that go with it - you'd have to unpick the 540's loom.
    This means the old 540is key should happily start your converted car...
    The key is coded to the ECU not the EWS system if I remember correctly? Shogun had an excellent post a while ago detailing all the parts of the EWS systems - and they're damned complicated.
    Jul 2007
    Long Island, NY
    Can I use an ECU from a '94 540i? The '94's didn't have EWS, right?
    I found a 4/93-built 540 locally with an ECU --- it is an Automatic car, but I should be able to use it.... ?
    -AJ
    Reading, UK
    Quote Originally Posted by Panzer Captain
    Non EWS ecu should work fine - though if it's out of an auto the idle might hunt a little bit ie +/- 100 rpm - there's a fix for that though all over the internets.
    Jul 2007
    Long Island, NY
    Will an ECU ending in 262 from a '94 740i work?
    -AJ
    Jul 2007
    Long Island, NY
    -Bump-
    -AJ
    Jul 2007
    Long Island, NY
    -Bump-
    -AJ
    Jul 2007
    Long Island, NY
    Help - Anyone know?!
    -AJ
  10. #20
    Jul 2007
    Long Island, NY
    Bump for help!
    -AJ
  1. Diff Swap: Research, Swap Procedure and Effect.
    Last Post: 05-28-2009, 02:53 PM
  2. DME Swap
    By stx133 in forum 5 Series BMW
    Last Post: 03-01-2009, 11:19 PM
  3. M50 / M52 Swap?
    By Spasso in forum 5 Series BMW
    Last Post: 08-22-2007, 05:52 PM
  4. OBC swap......
    By shuriken in forum 5 Series BMW
    Last Post: 07-04-2006, 07:09 AM
  5. m20 to m30 swap
    Last Post: 02-08-2005, 01:08 PM
