Originally Posted by
bubba966
Did the valve body rebuild include new check balls? There's 2 of them that wear and cause problems like you're describing. Symptoms of check ball wear are the tranny not fully engaging reverse (will slowly back up on level surfaces), and also engaging both forward and reverse at the same time. It sounds like you've experienced the forward & reverse engaging problem.
When you loose the reverse clutch pack retaining clip you loose reverse imediately (like it popped out of gear) and it won't work at all.
