Originally Posted by
MTechnik540i
Hey again folks,
Went to pick up the 540i today, and I must admit over a week and about $600-700 later, I was saying to myself 'this better fix this!.' Well, as normal, things start out promising, but just as always a few minutes into driving, when everything has reached temperature and the car is good and warm, the exact same issues start showing themselves again!
Needless to say, this is really frustrating. I suppose I'll be on the phone to Kirt again Monday, again, trying to figure out what's next.
So, if there's anything you guys can think of that I may want to check, please post away! I'm having to ask myself now, could this issue have nothing to do with the transmission at all.
TIA!
Did the valve body rebuild include new check balls? There's 2 of them that wear and cause problems like you're describing. Symptoms of check ball wear are the tranny not fully engaging reverse (will slowly back up on level surfaces), and also engaging both forward and reverse at the same time. It sounds like you've experienced the forward & reverse engaging problem.
When you loose the reverse clutch pack retaining clip you loose reverse imediately (like it popped out of gear) and it won't work at all.
