Thread: o-ring for coolant sensor giving me problems
    Jun 2006
    Default o-ring for coolant sensor giving me problems
    I just replaced the radiator in my M50 engine, however I am not sure where to locate the o-ring for the coolant sensor. I removed the old one and didn't see an existing one. I inserted the o-ring over the sensor inside the plastic nut, however I can't seem to thread it on to the radiator after doing so. Am I doing something wrong? Is there supposed to be a slot for this o-ring inside the nut or do I really have to force it on to get the thread started? For those of u that have done this, your input is greatly appreciated.
    TIA,
    Brooch
    1991 525iA
    M50
    Jun 2006
    check here, explosion view detail drawings
    http://www.realoem.com/bmw/select.do...938848d4d39ea1
    I have seen that diagram, but it doesn't really tell where the o-ring goes. It could either be inserted inside the plastic nut where I can't seem to get the thread started or inserted over the threaded part of the radiator which I haven't tried yet. Not sure which one is correct.
    Derbyshire, UK
    Push the o-ring down inside the nut. When properly positioned, it won't interfere with the threads.
    1997 535i V8
    Jun 2006
    Quote Originally Posted by DaveVoorhis
    thanks Dave, so I take it there is a slot the o-ring sits in or does it just sit at the bottom face of the nut? I tried threading the sensor with the o-ring sitting on the bottom face of the nut on my old radiator that I replaced and I couldn't get the thread started. I wonder if I have the correct o-ring? Its 2mm in diameter and it fits over the sensor tube properly. Guess I'll give it another go.
    Derbyshire, UK
    The o-ring sits at the bottom inside face of the nut. When properly placed, it holds the nut to the sensor but the nut spins freely.
    1997 535i V8
  1. AC Dryer sensor o-ring?
    By BennyM in forum 5 Series BMW
    Last Post: 08-09-2010, 04:58 PM
  2. 14k on o2 sensor and giving a
    By robertg in forum 5 Series BMW
    Last Post: 04-01-2004, 02:34 PM
  3. coolant expansion tank o-ring and level sensor proc.
    By bimmerd00d in forum 5 Series BMW
    Last Post: 03-02-2004, 12:24 AM
  4. problems on hubcentric ring
    By kamote in forum 5 Series BMW
    Last Post: 02-29-2004, 10:59 PM
  5. anyone replaced the coolant expansion tank o-ring?
    Last Post: 02-29-2004, 06:02 PM
