I thought the EWS system allowed you to kick over the starter motor, it just actually inhibited the ECU from fuel and spark?Originally Posted by playero
Hi, I've got a 95 525iA, the car have been in storage for a few. The other day my son took it out and the battery was bad, he got a new one and now the car won't start. All the lights on the dash come on and everything electrical does work, but when the key is turned to start nothing happenss. I don't know much about this EWS system, but could it be at fault?? TIA.
95/525i/auto/5/95 prod.date/18"rims/E31 FB/540i RB/ EAT chip/ blisteins sport/ bavauto springs
nope even starter motor...dunno about the e34's since i don't have one in my 525 but my '98 e36 has it.Originally Posted by Ferret
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
The reason I asked the above was because I thought there were different versions of EWS I/II/III? of which the E36 had II/III only fitted to it?Originally Posted by bmwrp8
I didn't know my car has this until I ordered the EAT chip and Mark literally walked me thru the check to see if it had it. Now I know why I had to pay $65 for a key and it took the dealer about 3 weeks to get it. i thought I was being s@#$%d about it. I will like to know if this is what is going on before my mechanic starts tearing it appart and sugests for me to buy another computer when all I will need is to have this thing "realign" again.
Okay, food for thought:Originally Posted by playero
Most of the key based immobilisers don't cause the starter motor to immobilise, my TDs is fitted with the transponder keys, and I have a duff spare key without a transponder in it. It quite happily turns the car over on the starter, but the engine wont fire.
If you have an alarm system fitted, this may be causing the interrupt as you've changed the battery and reset it!
hmmm.. that i have no clueOriginally Posted by Ferret
i thought all was the same.
OK, so I think I better have my mech look into testing the starter and see if this is the fault. I have no clue how this EWS work, so the inquiry. The car do not have an alarm on it so this is out. I hope is something simply, I need this car working by nov. as I will be home by then..![]()
try to use your spare key. thats what i did in my e36 and it worked..Originally Posted by playero
here
Drive Away Protection System (EWS)
Model: EWS I/EWS II/EWS III/EWS III D
E31/E34/E36/E38/E39/E46/E52/E53
Production Date: All since 1/94
http://www.unofficialbmw.com/images/BMW_EWS.pdf#search=
