Posting this for a friend trying to trouble shoot why his E36 backfires sometimes through the intake while cranking, and takes a lot of cranking to start (megasquirt 2, but setup just like my and other cars):
Symptoms: Car has issues starting, esp after engine is warmed up. Long cranks, intake backfires indicating lean mixture. Once the car does start exhaust has dark smoke in it.
Found the fuel pressure rail holds 0 pressure after cycling the ignition on/off. I even had a helper check immediatley after the car was off and already the pressure had dropped so much not even a drop of fuel exited the schrader valve on the fuel rail!
Where in the fuel system of the car (1996 328 OBD2) will it have a check valve?
fuel pressure regulator, fuel filter, fuel pump, fuel pump assembly?
