Quote Originally Posted by robert g
I have a 1994 525i and the blower motor works when you slam the door shut.... I replaced the resisitor under the driverside kick panel. I tried looking for a sword but could not find one... Can anyone tell me if this year car has one... I know it stopped working in certain speeds and I replaced the resistor and it worked fine... It works in all speeds.... I have not tried the relay? do you think by slamming the the door the relay will make it work/??? I did see a piece under the glovebox that has 3 different color connectors blue, white and black. Is there anything else I can check. Thanks again....Robert
To the best of my knowledge the sword was not used past about 1989/90. Your a/c is controlled by the blower resistor. Dunno about the relay, I'd look for a bad connection or a broken wire to the blower itself.
