Results 1 to 2 of 2
Thread: Changing brake Pads on 740iL
    Voorhees, NJ
    Default Changing brake Pads on 740iL
    Yeah, yeah I know this is an E34 web site and I have one. But I also purchased a really cherry 2001 740iL in March. Seems that the Check Brake Linings sensor just lit up. I have changed my E34 pads and rotors many times and replaced the brake sensors. Is the 740iL set-up the same or is there some new twist that I should know about? Also, a brief visual inspection of the rotors seems to indicate they are okay. I am looking to get away with just replacing the pads. Any comments, suggestions or words of wisdom would be greatly appreciated. By the way, thanks for your help with the oil change, Winfred. I was a piece of cake.
    Al Gray
    Nov 2006
    Mid-Atlantic, USA
    Everything's the same. I usually get at least two sets of pads per rotors. Just bed them in for a longer time before you really get on them.
  1. I Need Brake Rotors And Brake Pads!!!!!
    Last Post: 03-13-2009, 11:36 AM
  2. Changing front brake pads - 2001 740il
    By Al Gray in forum 5 Series BMW
    Last Post: 03-30-2008, 07:28 PM
  3. Whatelse should be done when changing brake pads?
    By dternst in forum 5 Series BMW
    Last Post: 07-28-2006, 02:40 PM
  4. Changing brake pads and rotors in your BMW
    Last Post: 07-14-2006, 03:01 AM
  5. Replies: 13
    Last Post: 03-11-2005, 09:25 PM
