Results 1 to 2 of 2
Thread: Small water pipe came out while doing water pump
    Default Small water pipe came out while doing water pump
    I've been in there all day. No amount of persuasion or WD-40 would ease the o-ring's grip on the small pipe. Finally it popped out of the back.
    What is my best option?
    1. Remove intake manifold and reseat pipes with new o-rings
    2. Remove radiator to pull the pipe all the way out, apply some blue Permatex at the end and push it back in place
    3. Just push it back in
    4. Other suggestion..
    Thanks in advance, your input is much much appreciated.
    Great Britain
    I'd go for option 3 but then I'm lazy.
    It seems that if option 3 doesn't work then you could always try option 2, and if that doesn't work then you'd get the "fun" option 1 of removing the intake manifold.
  1. Water pump out too far?
    By dennyg in forum 5 Series BMW
    Last Post: 10-20-2008, 12:43 PM
  2. Water Reservoir Clogged, Water Pump Leaking?
    By kelhami in forum 5 Series BMW
    Last Post: 04-28-2008, 03:01 AM
  3. Water pump
    By SilverFive90 in forum 5 Series BMW
    Last Post: 11-14-2006, 03:47 PM
  4. M30 Water Pump
    By athflying79 in forum 5 Series BMW
    Last Post: 03-20-2006, 09:35 AM
  5. Replies: 5
    Last Post: 12-09-2004, 11:20 PM
