So, what does it cost you where you live?Originally Posted by Zeuk in Oz
depends on how hot ya want it, real shine is probably in the 180-190 proof range, pure alcohol would be 200 proof, the more times you run it through the coil the more clean it gets but i am not sure how close to pure you can get, unfortunately i never got to run off a batch with my grandad before he died, that would be one cool vocation to have tucked away
Less than $20 Aus - call it US $17 to do the car.So, what does it cost you where you live?
'90 E34 M5
'89 E34 535i
'74 R90S
MB 560SEC
'74 Jensen Interceptor
'54++ VW Subaru Turbo hybrid
etc
Interestingly (or maybe not), it isn't possible to distill alcohol to purer than 95.6%. To remove the last few percent of water, the water needs to be remboved in some other way, e.g. by using a chemical (such as calcium oxide) to remove the water.
That's cheap. In the San Francisco Bay Area, where there are like 9 dealers, the price ranges from $22-30 PER GALLON (and the $22 price was for Mini brand coolant!). In contrast, SAAB "blue" coolant, which is Zerex G-48, sells for about $12 per gallon. I bought the SAAB.Originally Posted by The Bigfella
I think maybe Winfred was talking in old money. It used to say 70 percent 'proof' on a bottle of whisky (+e for Irish). In fact it was about 40 per cent alcohol by volume (ABV) which is how its marked today. Speaking of which I need to freshen my drink.......Originally Posted by pingu
unless something has changed since the days of yore 100 proof is 50% alcohol, 200 proof would be 100% pure, shine runs maybe 190 proof
Originally Posted by whiskychaser
peak global lifetime
J. Can I use PEAK Global LifeTime Antifreeze & Coolant in European and Asian manufactured automobiles?
Yes, PEAK Global LifeTime Antifreeze features an advanced patented technology that provides maximum rust and corrosion protection for cooling systems found in European and Asian automobiles. Additionally, the patented technology found in PEAK Global LifeTime Antifreeze meets the silicate-free coolant requirements of Asian car manufacturers and the phosphate-free requirements of European car manufacturers.
in america, which is the only way it is doneOriginally Posted by whiskychaser
proof is double percentage at 60f, which is the reason that it works out to double. in redcoat, modern tymes england measurement, it is also double, but originally the number was determined at 51f or such, which yields the 40:70 guideline.
