You wont be able to see the damage unless the head is off. If a piston hits a valve, the end of the valve is bent up but the top of the piston may be cracked too. There is nowhere for the energy to go and it is not unusual for a con-rod (connects the piston to the crank) to go through the side of the block. This hasnt happened in your case and as the car wasnt moving I would hope to you would get away with just the head.Originally Posted by leicesterboy15
