i get a creaking noise when i turn the wheels but only when the car is stationary. ideas??
The steering is making this horrible creaking noise. It's embarrassing and driving me nuts. Where is the noise coming from, ball joints, bushings, the pump itself? What's this about strut bearings? The noise seems to only be present when the tempurature is 75F or warmer. Somebody help me on this before I just replace everything! It's making me not even want to drive it.
is it A/T? mines the same its the breaks. if not probably the b.jointsOriginally Posted by Rory535i
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
just check your bushings, usually they are the culprits. check your ATF level too.Originally Posted by RX7guy
no it's more like a squeaky/creaking noise or a groaning coming from the steering box. the whole front end has new suspension parts and the fluids are all topped up
Which bushings?Originally Posted by bmwrp8
Not sure what you call it on LHD cars but here its called a steering relay,undo bolt on top, drop and lubricate,jack back up and noise gone.
No one else has experienced this?
reallyOriginally Posted by RX7guy
What exactly are you referring too? 'steering relay' do you mean the center tie rod?Originally Posted by Barney Paull-Edwards
