Not sure where you are but find an agricultural engineer,they replace boots regularly!
Been looking over the 540 and seen that the thrust arm ball joint rubbers are both perished and starting to split. The arms are only 6 months old and still good , so I'm looking to just replace the rubbers,so does anyone know what size the rubbers are at the base, top and hight of the rubber uncompressed.Anyone got a scrap arm lying about they could take a caliper to?
Cheers
http://www.southwalesprops.co.uk/pro...ball_joint.htm
No, I am not selling them to overseas. Too expensive to ship.Originally Posted by BigKriss
But here you can get similar ones
http://www.bmpdesign.com/product-exe...earch_model/47
http://www.horsepowerfreaks.com/sale...on_Accessories
I got these
http://8810.teacup.com/750hiline/img/bbs/0000382M.jpg
http://8810.teacup.com/750hiline/img/bbs/0000381M.jpg
sizes/openings:
33 x 15 mm part number 8501 3315
29 x 14 mm part number 8501 2914
Make is
TRISCAN smartparts from Daenemark
Ask them if they have an distributor in your area
http://www.tridon.dk/Default.asp?ID=223
They do not sell directly to private persons, only wholesale.
I had to order 200 pieces.
Note: the above is just one of the 2 I bought.
Not sure what size your Thrust arm has.
So one of these diameters
33 x 15 mm
29 x 14 mm
Interesting info, but no one got a new or old 5 series arm on the bench they could take a caliper to ?
Cheers
I just removed the LH thrust arm and doing the RH as soon as i get time, not sure what the rubber boots are like but will check and if they're ok i'll get back to you if you want them?Originally Posted by Sidney Rough-Diamond
