Check the wires inside the trunk before they go into the wire conduit on the trunk hinge. I had the same problem last week. I was not getting 12v on a reverse light and interior trunk light.
my passenger side taillight doesnt work. its not the bulb, i checked that, and the check control doesnt throw a code. a swift kick will make it come on usually. whats my problem? bad ground?
95 E34 540i6 M Sport - 94 E34 530iT B40/6 - 92 E34 525i5 M52/OBD2 rip
Common Problem
it might be common ralph but that doesnt really help me....my reverse lights dont work either. alt530, what did you do when you checked the wires?
All I meant by common problem is that you will find the answer just by doing a search. If you look on the driver's side inside of your trunk, you will see many wires running along the trunk hinge tube. These wires are easily crimped, cut and broken. Fix these wires and your problems go away.Originally Posted by indierthanthou
May be an iffy filament which makes a connection when you whack the light. Had this happen a few times. Try a new bulb then its out with the DMMOriginally Posted by indierthanthou
Sorry to come off defensive. But the taillight that is out is the one mounted on the body of the car, not the trunk lid. do these wires run to that too?
Different wires.
The reverse lights you mentioned are effected by the trunk hinge though.
Thats what I figured. I will check them tomorrow when its not dark time.
