Results 1 to 10 of 16
Thread: I am in Ball Joint Hell.....need help big time!
    Feb 2007
    Default I am in Ball Joint Hell.....need help big time!
    I got some time over the weekend so I decided to have another go at the control arms. I tried to remove the bolts at the crossmember for the upper arms and even armed with the correct tools this time I failed once again, the bolts just will not budge and I am now in danger of rounding them off so have decided to get them done at a garage, I don't have a clue how long they have been on for.
    I got the steering plate and lower control arm bolts loose without too much of a problem but then I couldn't remove the ball joint. The ball joint tool I had kept slipping, I've tried wiggling, tactical assult and just brute force and it will not shift at all. I went out and got a ball joint fork and managed to get the whole thing wedged in there between the arm and the steering plate and the fork just got stuck, the arm would still not release from the steering plate! It was quite rusty in there and the steering rods look like they've been there a while so I can only assume that the lower arms have been there a while too.
    Usually perserverance and gritted teeth get you through a job like this but not this time, I have run out of ideas and need help on how to get that ball joint out of the arm.
    I can't believe the fork didn't work, looking down from the top of the steering plate it looked like the bolt hadn't shifted at all and when I got the fork out there was still no play in the connection. Am I doing something wrong? The car is not driveable at the moment (or at least I don't think so) because I have made a mess of the ball joint boot and the bolts are not torqued. I have the car booked in on thursday to do the upper arms (£60 labour so not bad!) but I need to get it there. I have 3 hours tomorrow between getting home and it going dark to get the car driveable and any tips would be much appreciated. I tried driving the car up and down the driveway as well but that didn't loosen it. Is it best to try with the car's weight on the bushes so there no play there or on axle stands (as I have been)? If i need heat would a hairdryer do the job or does it need to be hotter and for how long? I've also been told that you can just snap them off but how do I do this, I can't see anything obvious. Is there anyway of disassembling the ball joint?
    Help.....
    did you use the bill r method?
    drop the cross bar to get to the bolts in back I had to because clearance issues. Kris's suggestion of Bill Rs is removing the whole knucke and beating it out on the floor.
    What I understand is you can't get the 'rear bolt' loosened and you've tried a puller of some sort as well as a pickle fork on the ball joint. The topic of thrust arm removal has been discussed here ad nauseam, so try a search.
    Can't say much about the rear mount as I've never encountered issues there. The fact that your puller tool is slipping off indicates you could find a better pulller. There are many pullers out there with different arm angles and ability to hold a small area such as on the thrust arm. I've used two which were successfull. The pic below shows a small one that worked despite its size.
    If you find you need to drive the car, don't worry about the boot being torn. As long you fit a bolt back on the ball joint, just get it where it needs to go.
    good luck with it.
    Dave
    Dave I'm pretty sure the rear bolt he is referring to is the back of the thrust arm. I had the same problem the 1st time I did mine, there just was NOT enough room for even the ground down wrench.
    good luck with it.
    Dave
    Dec 2005
    Mt. Vernon Ohio
    When I did mine (shut up jeffb) I improved on Bill R's method slightly with an oxy/acetylene torch, I then braced the thing with some random chunks of metal, took a big ass punch (halfshaft or something? My grandfather bought gobs of army surplus junk after WWII and it's still there..) and positioned it on the ball joint, and it only took one solid whack with the 10lb sledge.
    1993 525iA M50TU
    Black on Black...need pics
    208,888 miles
    Watch* it man* lol.... I got mine off with the pickle fork gammed in there and used acetyline torch also.
    *please note the "L" and "R" cast into the arms as to what side they refer to.
    Quote Originally Posted by NovceGuru
    When I did mine *(*shut up jeffb*)* I improved on Bill R's method slightly with an oxy/acetylene torch, I then braced the thing with some random chunks of metal, took a big ass punch (halfshaft or something? My grandfather bought gobs of army surplus junk after WWII and it's still there..) and positioned it on the ball joint, and it only took one solid whack with the 10lb sledge.
    * please see note above
    Feb 2007
    Thanks for all the input, sorry about the confusion, the arm I am referring to is no 2 in the image:
    http://www.realoem.com/bmw/showparts...50&hg=31&fg=05
    I have removed bolt no 15 but cannot get the ball joint separated from the steering plate. I think I will have to remove the steering plate as suggested and attack it off the car. I guess the general theme is lots of lube and brute force (the mind boggles!) Thanks for the input, at least I know I can drive it now if I need to.
    I love the way the Bentley says 'Tap the ball joint lightly to separate it from the steering plate' like its a breeze!
    bill r method ftw but forget that a shop will do your work. I mean might as well get them to do both upper and lower arms at the same time.
    to remove the steering knuckle, i think you have to remove the uppercontrol arm bolt anyway hmmmmmmmmm
    if you do the upper and lower control arms yourself, remove the nut from part number 7 while the steetin knucle is still attached to the strut.
    Feb 2007
    what is FTW?
    I did think that if I remove the plate then I am half way to removing the upper arm anyway! And what if that ball joint proves just as stubborn?! I think I will have one last bash at it tonight (I only have a couple of hours free) and if it doesn't work I will torque all the bolts up and let the garage do it. I am disappointed that yet again I haven't managed to do it but I have built up a mean array of tools as a result of this job and I have learned a hell of a lot. Maybe I should just conceed that I don't get enough time anymore to do all the car DIY that I want to do.
  1. Ball joint... but which one ?
    By Claude in forum 5 Series BMW
    Last Post: 10-23-2008, 05:45 PM
  2. Help! In ball joint hell
    By 530iBall in forum 5 Series BMW
    Last Post: 09-30-2007, 03:59 PM
  3. Bottom ball joint
    By gazz200581 in forum 5 Series BMW
    Last Post: 07-06-2006, 05:03 PM
  4. Ball joint
    By mamilapon in forum 5 Series BMW
    Last Post: 07-06-2006, 03:01 AM
  5. ball joint tool?
    Last Post: 05-08-2006, 08:16 AM
