Results 1 to 10 of 13
Thread: What's this warning mean????
    Bimminator Guest
    Default What's this warning mean????
    Hey all, My 535i has been running pretty crappy for the last few weeks. It sat for three weeks while I was in France and when I got back it wouldn't start right away. I had to keep turning the starter motor and finally got it started after about 15 min. Shortly after I was on my way the car started sputtering and jerking and then stalled on me. It started again right away but would stall when I put it in drive and pressed the gas. The warning light that lit up was the one below the temp. gauge that looks like an exclamation mark inside a circle (!). Eventually after the car ran a little longer all problems went away and the car hasn't done this again in the last few weeks. Today however when I was coming home from work I lost all my gauges and that warning light was on again but the car ran fine all the way home. I don't have an owners manual so could some one be a dear and educate me on what this symbol means and why my car might be acting this way? I did a search but could not find anything related to this.
    Thanks, Shawn
    Mar 2004
    NSW, Australia
    Check Engine!
    I think the check engine light is the one that reads "check engine". The (!) symbol is a brake failure warning.
    Bimminator Guest
    That is strange that the brake failure warning would show eventhough the brakes are working fine. New pads and rotors up front plus a bleed three months ago and rear had about 1/4 life left. Why would I also lose my speedo, rpm, and fuel gauge while this warning was showing? Turn signals still worked, as well as emergency brake signal.
    Shawn
    Great Britain
    I too thought that the (!) was a brake warning.
    Honolulu
    It could be a couple of things.
    Low voltage= check your electrical system, battery, grounds and leads to and from that fusible link box.
    Bad caps in the dash cluster.
    Bimminator Guest
    Quote Originally Posted by Blitzkrieg Bob
    Thanks, I'll do some digging around. Battery is a little less than a year old so I'm sure that is fine but I have been suspicious of the grounds as I have a few intermitent electrical gremlins.
    Maybe the fusible link has a haircrack.
    Sometimes works, sometimes not.
    Feb 2007
    GreenHills East-Philippines
    hey shogun! its been a while since i see you post anyway if the f.link has a crack does it affect the cluster?
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    Quote Originally Posted by bmwrp8
    Sorry, I am a bit busy at the moment and also was in Germany last month. Have to go again next week there.
    It could affect the cluster too, I assume, depending on where the connection is.
    But that is just a guess.
    Anyway, for such cases fusible link is always a suspect.
  1. Warning chime
    By Vanguard in forum 5 Series BMW
    Last Post: 10-28-2017, 02:35 AM
  2. low coolant warning fix
    Last Post: 01-29-2012, 08:21 PM
  3. OT: I'm getting hot warning
    Last Post: 06-22-2009, 04:27 PM
  4. low pressure oil warning
    By ram5757 in forum 5 Series BMW
    Last Post: 02-21-2006, 02:50 PM
  5. Low beam warning fix
    By rockyfeller in forum 5 Series BMW
    Last Post: 07-21-2005, 12:20 PM
