I have a 535 so not sure about your car have a look here and see if it helps
http://www.bmwe34.net/e34main/mainte...il_service.htm
howdy all, hope your well
i'm cringing while i type this because i SHOULD now the answer to this question!
where is the oil filter located on my 525i
it's dark and raining outside and i've done a quick search. i can't remember seeing it anywhere last time i was under the car
regards and sorry again for such a newb question
s
89 535 272,000km auto Euro
Its right above your alternator, its in an alumnium case with a cap that has a bolt.
DOH!
i knew that, feel like an idiot for asking now
thanks fellas!
what oil are you guys using, out of interest?
regards
s
castrol magnatec on mine 20w-40. but i guess you should use synthetic.
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
10/40 semi synthetic. In your new filter box you should get new 'O' rings for the filter bowl and spindle and a 'copper' one for the sump plugOriginally Posted by bigtallsam
Mobil 1 0W-40 (as per the manual's recommendation).Originally Posted by bigtallsam
Otherwise, I would run a Pennzoil dino-oil product like I run in my wife's Sable. I've had good service out of Pennzoil and like the idea that the oil they use is supposed to be a paraffin base (no sludgey crap like asphalt-based dino oil).
The only good reason to run a thicker than recommended oil for the expected temp range is to quiet an older engines noises. In a healthy engine, all that thick oil is doing is robbing you of gas mileage while it wears out your oil pump due to the pumping friction when cold.
Brian
Brian
Oil is a topic that has been discussed here a world over. Personally I use synthetic, I recommend a heavier weight like 40 over the 30 cuz u can have a potential for bigger leaks. Notice I said bigger, using synthetic on an engine that never received it can cause leaks, but dont be alarmed at most its just seepage from the valve cover, especially on the M50. Anyway, i used Mobil 1 10W40 high mileage great stuff.
