Argh, you've lost the bolt or the removal tool? o.OOriginally Posted by Barney Paull-Edwards
So after 22hrs on watch I drove home and still awake, decided to fit refurbed M5 wheels to TDS.Bad move, first one on,solid on strut, need spacer, no problem, fit spacer,easy-peasy.Go to other side,fit M5 calliper, bleed and on with wheel, easy. At this point the wheel lock bolt rolled gently across the floor and down the drain, down three feet to a slurry pit. Now have a wierd set of brakes and wheels,why did I get up this morning???????
so the tds,s have different wheels to other e 34,s?
Gone but not forgotten
Sounds like e36 wheels to me... what m5 calipers did u fit? Or maybe the M5 arms have a narrower track... the hubs are different too, and the brakes! Weird... what mods have you done exactly?Originally Posted by Barney Paull-Edwards
you know, Kennedy looked good in the back of a 4 seat convertible.
I thought that was November 22nd. Must be missing something?Originally Posted by repenttokyo
Originally Posted by whiskychaser
it's in reference to the original poster's sig.
Moral - open eyes before mouth. My apologiesOriginally Posted by repenttokyo
no worries![]()
Sig was stolen from the book of Clarkson! Fixed lock problem with spline drive, snap-on driver and hammer, can be done.Seems to me that M5 E34 struts have about 13mm more offset than both 535 and 525TDS struts, tried both.Face of rotor is same thickness so am lost for answer.535 was early so ABS sensor was in different position,hub was slightly different but it fitted.Now going back to TDS legs and will build them properly with Sachs inserts, Eibach -30 springs,M5 `91 brakes and new bearings, late M5 bi-metal rotors will fit and were cheap via Ferodo for once.Got an independant engineer to give car a once over to avoid throwing good money at wreck, full compression and oil pressure after 295k is a testament to good build quality,try that with a new one without bumpers, do designers ever drive in the real world???!!!
