Check your temp guage against a known good unit..
guys a little help.Friends e39 was overheating so we bled the rad still the same...checked and saw the aux fan was always in LOW mode and high mode will only kick in if the temp reached 3/4ths which is high! What we did changed the radiator, water pump , thermostat , and fan switch to 81/88'c...still the same. Aux fan will only kick in high mode if the needle reaches almost 3/4ths which is almost overheating. My e34 kicks in high just before the 12oclock position. any thoughts? thanks guys..
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
will try to put in a diff.cluster to see if it changes. will let you knowOriginally Posted by mamilapon
ok update, just installed a second cluster still the same. 3/4ths before aux.fan kicks in high.bled again still the same. Any ideas??Originally Posted by mamilapon
i am not an expert but i'd be looking to see whether there is a high temp coolant switch that controls the aux.fan. and then seeing whether its working properly.Originally Posted by bmwrp8
something like no. 6 http://www.realoem.com/bmw/showparts...05&hg=17&fg=05
just changed the fan switch(80-88'c) in the side radiator still the same...I wonder if there is a second one...but i guess not.Originally Posted by rob101
well maybe, there is a problem with electronic thermostat also.
it shouldn't be going anywhere near 3/4 even if the aux fan is meant to kick in
we've just changed the thermostat too. is there a second one? whats a electronic thermostat?Originally Posted by rob101
hmmm i should have really read your first post :-P, no i am pretty sure there is only one :-POriginally Posted by bmwrp8
well you've kind of replaced everything but the fan clutch, which means It could be your main fan isn't cooling enough
