Originally Posted by
Jr ///M5
Tap on the bottom of the oil pan, the sensor is stuck, it's where the three bolts surround a circular disc. This should clear the oil sensor problem.
Try tapping the coolant level sensor in the same manner, be gentle now, it's located near the top left hand part of the radiator and as you know, the radiator and associated fittings are brittle. It's actually screwed into the radiator. A slight tap could dislodge something that is causing a short, or disconnect the wires and give it a shot of contact cleaner. If it still fails to clear the message, you'll have to swap the sensor on the fly after the engine has cooled down overnight. Use teflon tape to help get a good seal, but don't overtighten!
The sensor wires are shorted in the brake circuit. You will have to pull the calipers and check the pads to see if the contacts located in the inboard pads are worn down or broken. If not, disconnect the sensor wire at the coupling and clean the connection with a spray contact cleaner and reconnect. The sensors are located at the drivers side front and passenger side rear.
Hope this helps,
JR
