Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: 530i doesnt start. HELP!
    Roswell New Mexico
    i would do a fuel pressure test before anything.http://cgi.ebay.com/ebaymotors/Inlin...spagenameZWDVW autozone has some too.
    And if fuel pressure is fine and there is no spark then what?
    my 94 doesnt have coded keys.
    Quote Originally Posted by Ferret
    Finally, his keys havent suffered some trauma have they? They're coded keys after '92-'94 and you cant start the car without them, it'll happily turn over but wont even bother firing.
    Roswell New Mexico
    no spark could be bad coils. before i would buy coils i would then check CPS. or coded keys
    Derbyshire, UK
    Quote Originally Posted by 94_e34_525i
    I see, there must be a safer way cant i just disconnect the connector and check it with a multimeter?
    You can't check for spark using a multimeter, unless you want to destroy the multimeter.
    And lets say there is no power to the coils what causes that?
    A bad Crank Position Sensor, failed ECU, or an active immobiliser are typical culprits.
    1997 535i V8
    Thanks for the wealth of info, I will keep you guys posted on what happens. Thanks again.
    baton rouge, loserana
    8 coils are not going to go **** up at the same time, if it has fuel or spark then the crank position sensor is working
    Quote Originally Posted by Dr. evil
    Roswell New Mexico
    i guess im wrong
  1. 530i (M60) No Start?
    By nirvana19 in forum 5 Series BMW
    Last Post: 12-29-2008, 01:25 PM
  2. 95 530i - Won't Start
    By REtzler in forum 5 Series BMW
    Last Post: 08-19-2006, 06:06 PM
  3. Very cold start 530i
    By uberhahn in forum 5 Series BMW
    Last Post: 12-19-2004, 06:18 PM
  4. 530i won't start
    By Nicole in forum 5 Series BMW
    Last Post: 06-21-2004, 12:29 PM
  5. Replies: 5
    Last Post: 04-11-2004, 08:47 PM
