Results 1 to 4 of 4
Thread: 1989 520-I service indicator
    Apr 2007
    Ridgecrest CA
    Default 1989 520-I service indicator
    i cant believe that i cant seem to reset this simple indicator.the method im using,ign off, short pins 7-19 in diagnostic socket.ign on for 4 seconds for an oil service or 10 seconds for an inspection.remove shorting wire,replace cap on socket,turn the ign off again. my questions,im still in the green scale on the indicator,do i have to be in the yellow or red?.i have no secondary indication that this is for a inspection.i just got the car running and want to start fresh.what is the duration criteria for this indicator.my owners manual says consult the service handbook but it is simply full of authorized bmw repair facilitys world wide. thanks bones.
    Ign. ON
    Apr 2007
    Ridgecrest CA
    Default that was easy
    Ign. ON
    ok,so im going to leave ign on for the entire procedure.im guessing by your two word response that this is such a simple task that it dosent even deserve any additional info.ill try again. thanks bones
    Reading, UK
    You have any luck with this then?
    My TDS wouldnt reset until I shorted the pins for 20 seconds...
  1. Service indicator wont go off ...help plz
    By jstew4u in forum 5 Series BMW
    Last Post: 07-21-2008, 04:41 PM
  2. Service Indicator
    By Golgade in forum 5 Series BMW
    Last Post: 05-14-2008, 12:58 PM
  3. service indicator batteries ?
    By bones in forum 5 Series BMW
    Last Post: 06-10-2007, 11:13 PM
  4. Oil Service Indicator/Yellow
    By Jehu in forum 5 Series BMW
    Last Post: 09-30-2006, 02:47 PM
  5. E36 Service indicator lights
    By Unregistered in forum 3 Series BMW
    Last Post: 05-31-2004, 02:15 AM
