View Poll Results: What wattage tail lights do you use ?
Voters
12. You may not vote on this poll
  • My owner's manual says 5W and I use 5W
    4 33.33%
  • My owner's manual says 10W but I use 5W
    0 0%
  • My owner's manual says 5W but I use 10W
    1 8.33%
  • My owner's manual says 10W and I use 10W
    1 8.33%
  • Who's Winfred ?
    9 75.00%
Multiple Choice Poll.
Results 1 to 10 of 12
Thread: Tail light wattage
    Aug 2004
    Regional NSW, Australia
    Default Tail light wattage
    "I'm not the village idiot.
    the most common **** up i see on e34s is dumbasses using 1156 (old # for 21w single element) in the 5 watt hole (lower inside) destroys the light by melting it, so i am not really for anything but what that position calls for, and it's generally stamped on the back of the light, occasionally ill grab all of the lights off the shelf and see how many of them i can make work again so i sell them, i sometimes can melt them and get the hole and contacts back in to the right shape
    Aug 2004
    The reason for the poll is that I have 2 E34s, one owner's manual ('94) recommends 10W globes and the other owner's manual ('88) recommends 5W globes.
    Australia
    Thats what someone had done to my car. I bought some used lights from ebay to fix the problem cheaply.
    Hmm, that is intresting how the manuals say two different things, probably cuz, the newer one has a more powerful alternator (m50) then the older car (m20).
    EAT Chip/K&N Panel Filter/Blaupunkt MP46/JBL 15" sub/Crimestopper Alarm/e38 basketweaves/Deutschland Plate/Clear Corners
    Dec 2006
    North Tonawanda, NY
    I had a lot of issues after a previous bulb replacement used a wattage higher than recommended. The $.99 bulb only cost me $40 to replace housing after meltdown caused the contacts to shrink away from the bulb fitting.
    six forward speeds
    perfect example, you can see the 10w moulded into the housing, i go with what the light wants
    Quote Originally Posted by BuckNaked
    T·O·R·O·N·T·O
    I use tower LEDs...
    Oldham, England
    Quote Originally Posted by Zeuk in Oz
    Not replaced any rears. But side lights are usually 5W and brake lights 21W. Think that may even be a UK standard.
    Dec 2005
    Brisbane Australia
    Quote Originally Posted by whiskychaser
    Not really, EU standards are set on luminance not lighting power as are most developed countries (ie US and Australia). the standard looks at the lights in general ie the reflector as well. a 5W in a certain reflector will give a diff value of luminance than another. you can replace the bulbs as they are standardised unlike LED's where you have to replace the whole light cluster.
  1. Brake Light, Tail Light, Licence Plate warnings
    Last Post: 09-24-2007, 05:01 PM
  2. Tail light wattage ? What wattage are you using ?
    By Zeuk in Oz in forum 5 Series BMW
    Last Post: 08-30-2007, 04:45 AM
  3. Can someone take their tail light off for me...
    By SchnellE34 in forum 5 Series BMW
    Last Post: 04-27-2006, 11:28 AM
  4. I need a LH tail light.
    By Beez540 in forum 5 Series BMW
    Last Post: 08-22-2005, 02:24 PM
