Results 1 to 10 of 19
Thread: Oh boy: Door brake/hinge failure
    Sep 2006
    Default Oh boy: Door brake/hinge failure
    My driver's door brake/hinge has been messed up for as long as I've had the car. You could see where the door brake was going into the soft metal of the door. The hinge made noise for a while, a bad knocking-type of noise.
    When the car was in the shop for the fuel pump, the hinge failed on the mechanic. The door wouldn't shut. He had to remove the door and cut the hinge off! I can't believe it!
    So now no door brake until I can get it to a bodyshop. I also need a new door brake and pin.
    I know about the KMS reinforcement plates, are those necessary? What else do I need to order?
    Thanks!
    Maryland
    Can you take a photo of it and let us see the damage, if any?
    Sep 2006
    Quote Originally Posted by Evan
    My camera was stolen...I'll try to get a hold of one tonight or tomorrow.
    The goldish hinge and black boot are gone. The metal on the door is gashed/ripped. Paint flaking from where the metal was pushed in.
    Basically, now the door has no resistance. Since there's no door brake, you have to be careful and always have the door under your control...don't let it go too far!
    Honolulu
    A good body shop could fabricate a panel and repair the door.
    the KMS fix is more of a DIY bolt on thing reinforcing the section that blew out.
    Sep 2006
    Quote Originally Posted by Blitzkrieg Bob
    Ahh, thanks!
    The good Euro shop recommended a bodyshop that's done a few of these. We'll see what he says. I have no idea of how much this will cost!
    Victoria, Australia
    How'd you go? Mine just broke!!! Ripping it apart today to see what's up.
    Old car: 95 525i, OB/Silver, Eibachs, Style 66, Missed dearly!!
    VIN Decoder | Online ETK
    | E34 Bible
    Victoria, Australia
    Pulled mine apart and found that one screw is still where it belongs whereas the other screw has ripped thru the metal
    Got some photos so will upload soon. As far as getting it out, I haven't tried yet. How do you get the pin out of the door brake so I can remove it? Just with a hammer?
    | E34 Bible
    Victoria, Australia
    | E34 Bible
    La Mirada, CA
    so those kms things r legit?
    Sep 2007
    Seattle, WA
    Quote Originally Posted by BFEINZIMER
    Yes they are. I'd install a set on your front doors to prevent the brake from pulling out of the door.
    My car has a KMS plate welded to the door and painted. Guess the PO had it start to rip on him.
    My buddies '93 M5 had one of his brakes starting to pull the metal out, hadn't ripped yet. Got the KMS plate on and it flattened it all out and will keep it from getting worse.
  1. Fuel Door Hinge
    Last Post: 05-03-2009, 09:34 PM
  2. Fuel Door Hinge Replacement
    By Super90 in forum 5 Series BMW
    Last Post: 08-14-2008, 09:44 AM
  3. door hinge makes noise
    By robert g in forum 5 Series BMW
    Last Post: 06-06-2007, 02:16 AM
  4. Procedure for gas filler door hinge
    By willobmw in forum 5 Series BMW
    Last Post: 04-03-2004, 01:06 PM
