Results 1 to 10 of 13
Thread: Name that whine!
    Reading, UK
    Default Name that whine!
    Okay guys, gonna need a hand with this one...
    While sat in the drivers seat, I can hear a whine coming from behind me while the car is in overrun.
    Decelerating anywhere over 20 mph and I get a drive train whine.
    I'm not sure where this is coming from... as when I sit in the rear seat while someone else is driving, I cant hear the whine noise.
    My first instinct is to point a finger at the differential, but I'm not 100% and dont want to go throwing money at a rebuild without knowing first. Can anyone recommend a fluid to change into it to see if it'll shut the hell up?
    These differentials have an incredible ratio on them, it's barely ticking over at 70mph in top gear, as the diesel torque allows it to really fly. I could try swapping a 540i diff into it as it's the closest ratio I'm going to be able to find , and see if it goes quiet under there...
    However the rear suspension cage on the diesels is weird, it doesnt have any of the under-diff ladder frame in place
    EDIT: Anyone had any experience bearing changing/rebuilding a diff?
    May 2006
    Antwerp, Belgium
    Quote Originally Posted by Ferret
    Define 'overrun'?
    Sure it's not wheelbearings? My old E30 had a bad wheelbearing which would get real loud at speed. lifting the rear with transmission in neutral and turning each rear wheel can tell you what's up. Have someone hold a wheel and then turn the other. Makes it easier to locate noises and excessive friction. Just be careful with the front wheels. They need to be firmly fixed, though something tells me you of all people should know all this?
    2008 audi A3 1.9tdi
    (former 1991 520i LPG)
    If overrun is off throttle, coasting then I agree with you pointing to the rearend. Not the diff but the ring and pinion. Put some fresh oil in there and see if things improve.
    Lots of miles?
    Feb 2007
    New Forest, ,UK,
    EDIT: Anyone had any experience bearing changing/rebuilding a diff?[/QUOTE]
    Dont drop the oil all out,add some Wynns and see if it goes.I have spare 535 diff so you are welcome to swap, leave me the original and I`ll do the bearings,do not have tolerances but cannot be too tricky, done toyota, Range-Rovers and all three of Metro`s(two bloody times!),bought engineers blue in bulk for that one.Does yours have an LSD, if so remember they use different oil and Wynns will piss it off.
    Oldham, England
    Jack up the front end. Grab the tyre at 12 and 6 o/clock and wiggle. Yes 2inches is small but a bit too much for a bearing
    Edit: Must have been replying to another thread or need more water with it. But I DO know what over-run is:-)
    Been there done that...
    http://www.bimmer.info/~regal632/rearend.html
    Hey Jeff, I have the same press you do!
    Feb 2007
    New Forest, ,UK,
    Default ??????????
    Anybody who praises Smokey Yunick is a God themselves! His variable displacement V8 is in a museum near here, now that man defined lateral thinking, or downright sneaky!
    Reading, UK
    Quote Originally Posted by Barney Paull-Edwards
    Okay guys, I'm now more starting to think it's the centre bearing and/or a universal joint...
    After having crawled all over the back of the car while the wife was driving, I was starting to get confused. While sat in the back seat, you can hardly hear the noise at all - and it felt like it was coming from in front slightly.
    While sat in the drivers seat it definitely sounds like it's coming from behind you.
    A few days on and there's a metallic hissing noise coming from under the rear seats which is making me think that the mechanic who changed the Guibo didnt re pre-load the centre bearing and after the abuse it was put through while the guibo was deadded, the bearing and/or the nearest uj is now packing in...
    Any thoughts on this guys?
    That hissing sound you descibe makes me think pinion bearing. If it doesn't change between load and coast then look to the bearing.
  1. Help Identifying a Whine?
    By Jehu in forum 5 Series BMW
    Last Post: 02-16-2010, 10:13 PM
  2. Whine from under the car
    By ArnZ! in forum 5 Series BMW
    Last Post: 12-17-2009, 11:14 PM
  3. '89 M20 Auto Transmission whine, how much do YOU have?
    Last Post: 01-13-2007, 03:16 PM
  4. 540i tranny whine
    By zhandax in forum 5 Series BMW
    Last Post: 03-17-2006, 05:13 PM
  5. whine noise...
    By beamerman5 in forum 5 Series BMW
    Last Post: 09-11-2005, 11:06 PM
