Thread: Lkm
    Mar 2004
    NSW, Australia
    Default Lkm
    Now is there there anyway of testing the relays in the LKM individually?
    I thought I fixed the bastard but its playing up again.
    Also resolded all the joints between pins 2 and 22 as per Javier's advice , still no go
    Albuquerque, NM
    Cut a narrow strip of 320 grit or finer & drag it thru the points. Put a little pressure on the points while doing it:
    You can take a pair of tweezers & carefully bend the copper tab slightly to make sure the points close with more contact pressure.
    gale
    Mar 2004
    NSW, Australia
    Shall do mate, in fact I have seen evidence of arcing on one of the relays , i hope its the culprit. Shall keep you posted!!
    Mar 2004
    NSW, Australia
    Used the 320 grit strip and bent the tab. Also did a little more soldering. Still no go. With ignition on, and low beam selected Im getting 9.99-10V at the yellow plug. Ive ran out of Ideas!!
    Nov 2006
    Maryland
    may i suggest a new lkm? too bad i just sold the last one i had...
    Mar 2004
    NSW, Australia
    Im sure there's a fix I want to try all the avenues first before considering a new one.
