Results 1 to 2 of 2
Thread: Steering Wheel Removal
    Nov 2006
    Default Steering Wheel Removal
    Quick silly question...
    Will anything bad happen if I disconnect the battery of my '90 750iL to remove and replace the worn out steering wheel? Aside from having to reset the clock, etc.
    vince
    1990 750iL
    Built 7/89
    VIN# WBAGC8313LDC76016
    Naperville, IL
    you have to resynchronize the 2 throttling valves thru the EML. Procedure is on my website below.
    Also note down radio code and code for anti theft devices if installed.
    Disconnecting the battery: no need to remove the rear seat which is a pain in the a$$ on electric rear seats. In front of the rear passenger seat there is a plastic cap, remove this, remove the nut on the bolt underneath, then remove the next plastic cover and you see the bolt which holds the battery cable there.
  1. Replies: 14
    Last Post: 11-30-2013, 10:33 AM
  2. steering wheel w/airbag removal
    Last Post: 08-08-2006, 01:32 AM
  3. Replies: 13
    Last Post: 03-28-2006, 08:34 AM
  4. Junkyard steering wheel removal
    By Kristuphir in forum 5 Series BMW
    Last Post: 03-12-2006, 10:41 PM
  5. Cluster removal without steering wheel removal...
    Last Post: 02-18-2006, 04:08 PM
