what are the related components?
Hi, I had an indi put in my new springs/shocks/control arms and related components. Now my steering will not return to center. And the steering feels like I also have rear wheel steering. When I turn, there's a slight sound that sounds like rubbing (very slight). He told me to go get a wheel alignment first and then see what happens. I'm very concerned and haven't driven the car over 45mph. Help!
frt control arm
thrust arm
pitman arms
idler arm
bushing
sway bar link front
center link
tie rod
I won't have internet anymore tonight. Will check back tomorrow morning. everything I replace is OE for a 95 540i 6sp. Thanks
the alignment should have been done right after the suspension job.
Last year the garage I used insisted I needed a new centre tie rod to pass the MOT. (Thats what real.oem call it) The new part was slightly longer than the old one and totally screwed up the steering to the extent it would not self centre at all! Pretty hairy when you come round a corner and have to heave the wheel back. I also got the scraping noise from underneath the front. The new part totally screwed the alignment but once that was corrected it handled fine. I just had it rechecked and it was one degree out. But I never did find where the noise came from.Originally Posted by txp135
i think its faIled upper strut bearings. my car doenst return to center by itself. when i did my front shocks the bearings inside the front mounts were really rough and the one was kinda loose. they didnt spin smoothly. have you checked those? i should have replaced mine when i was in there but i dindt have the money. sigh.
Mark
1999 M3 Cosmos Black/ Black 78k
1994 540i Oxford Green/ Silver Grey Sold @ 133k
1995 M3 Arctic Silver/Black Sold @ 117k
1990 325i Zinnobar Red/Black Sold @ 115k
its possible that they installed the control arms on opposite sides....Someone did that very thing about a month ago...not mentioning any names (Alexlind)![]()
you can't mess with the steering and then not align it...
head for a quality alignment to take that out of the equation!
I think if he has changed the pitman arm he must hve put the replacement part the wrong way.
Bashin the 'Lind?Originally Posted by 632 Regal
YOU GONNA DIE MOFUGGA!
WEST COAST GANGSTAZ!!!
EuroLux:. Private Detail
