Results 1 to 2 of 2
Thread: Head bolt torque questions
    Default Head bolt torque questions
    Bentley says to torque head bolts in stages to 58 ft lbs. then after running the engine, another ~35 degrees.
    Question: After the angle torque of ~35 degrees, what is the equivalent final torque setting in foot pounds?
    Another question: How to properly calibrate a torque wrench, to make sure it is accurate?
    Dash01
    '90 535ia 272K miles
    baton rouge, loserana
    there is not really a equivalent foot pound reading, just give em about 1/8th of a turn, what you are doing it putting the bolts into a elastic state, as for calibrating a torque wrench it depends on the brand of wrench on where you start looking for someone to tune it up, most of the time they are only with in 10 percent of dead on any way, sorta one of the reasons for the angle torque, the actual torque # is not super critical but getting a even torque across the head is more important
  1. M50 crank bolt torque?
    Last Post: 03-18-2008, 10:06 PM
  2. 540 guibo bolt torque setting
    By yaofeng in forum 5 Series BMW
    Last Post: 10-03-2006, 12:38 PM
  3. proper wheel bolt torque 72 ft lbs?
    Last Post: 03-15-2006, 02:28 PM
  4. Thrust arm bolt torque under load? THE SHAFT!
    Last Post: 08-16-2005, 09:56 AM
  5. final head bolt torque question
    By tjn in forum 5 Series BMW
    Last Post: 11-19-2004, 01:53 PM
