Results 1 to 3 of 3
Thread: 5 gas analyzer and AFM adjustment
    Agoura Hills, California
    Default 5 gas analyzer and AFM adjustment
    Well im almost done with my driveshaft, tranny, clutch and oil pan gasket rebuild. Let me tell you, it was a nightmare thus far. Especially when i got to the pressure plate bolts. They were completely stripped! Had to weld two beads on the bolt and remove it with vise grips. Anyway though......
    Since my smog values were a little high and my car smokes a lil when i am above 4k revs (with full throttle as well) i am assuming it is an adjustment issue with the AFM, since i messed around with it a while back when i had an idle issue. I was wondering if anyone knowabout a cheap little 5-gas analyzer or a shop in the LA area that would be willing to help me out.
    Oh and one other thing. For a gasket sealer im gonna ue HONDA BOND. Any suggestions or pointers when using this stuff? or is there something better out there? every person i have asked has suggested honda bond. Thanks again
    1990 BMW 525i m20 SOHC 5-speed 140k miles, black on black, stoc
    http://www.born-today.com/Today/pix/tyson_m.jpg
    MAN WHAT?!?!...
    Everyone has to go on U-Tube and watch mike tyson interview
    What color smoke?
    Bellevue WA
    86 Porsche 951 - Track Toy
    Well its kinda hard to tell....I wud have to say black smoke.
    Ive done a compression test (results looked good-dont have the numbers of hand)
    I have replaced a lot of gaskets and stuff around the car.
    I have been told it cud be the water temp sensor, air temp sensor, TPS, or AFM adjustment. My smog levels were all pretty high, and considering the fact that the car has power (for an m20) andthe only thing I have messed with carelessly in the past is the AFM adjustment screw, I am assuming that is the culprit. What other options could I have?
    MAN WHAT?!?!...
  1. UK headlight adjustment
    Last Post: 09-20-2009, 08:18 AM
  2. M20 Valve Adjustment...
    By TheEndIsNear in forum 5 Series BMW
    Last Post: 08-28-2006, 02:59 PM
  3. AFM Adjustment...
    By Rustam in forum 5 Series BMW
    Last Post: 05-19-2006, 02:07 AM
  4. Headlamp aim adjustment....
    By High Compression II in forum 5 Series BMW
    Last Post: 11-12-2005, 01:42 PM
  5. Seat adjustment
    By Rory535i in forum 5 Series BMW
    Last Post: 04-18-2005, 07:28 AM
