Dont worry about the job, it's literally a case of 5 bolts a wheelOriginally Posted by e34.535i.sport
You'll need a breaker bar, you wont be able to do this job without it.
Some thoughts:
There's two difficult spots to this - firstly getting the caliper carrier bolts out and then getting the locking/retention pin out of the rotor/disk. If your car is on its original rotors, you're probably looking at a set of seized locking pins - you're going to need to drill them out.
Which means you end up with a hub with half a locking pin in:
You can either drill this and pull the stud out, or if you're lazy like me you'll have only drilled the eact amount necessary to get the rotor loose - and not bother removing the rest of it, using the calipers to hold the new discs in place rather than the locking bolt.
I did get pissed off with one side as my drill was getting flat batteries- and took a lump hammer to the rotor on the opposite side to the locking bolt. The whole rotor just jumped off the hub with about three hefty blows. I wouldnt recommend this though as you then have to somehow extract the bolt from the hub with some sheared metal around it. Chisel and file needed.
Getting the carrier bolts out requires a fair bit of force, but so long as you've got a long breaker bar, they /will/ come out. Having said that - my flat mate who's not particularly a big guy couldnt get them to come out - whereas I could put a bit of weight behind the bar and cause the bolts to pop free. These are easy to do on the front wheels, but you might have to get physical to access the rear ones. For this task you need a high quality socket because of the huge amount of force you need to transmit.
Other things you'll need: Copper grease - if you dont grease up the back of the pads they'll make a horrific noise every time you touch the brake pedal - hugely embarassing.
A good quality Hex drive - avoid the halfords hex drive 7mm tool - mine kept exploding and nearly took my eye out once - they just cant cope with the torque required to get the caliper guide pins out...
I'd recommend a good pair of axel stands for this one due to the force required - although I was and did it on the widowmaker jack that comes with the car.
